Thread: Other ZX14 Forum
Created on: 02/15/20 12:56 PM
bobk
bobk's Gravatar
Other ZX14 Forum
02/15/20 12:56 PM
Anybody know what happened to the other forum as they are no longer there it just takes you to a Facebook page. I Hate Facebook!
Ft. Lauderdale
RE: Other ZX14 Forum
02/15/20 1:38 PM
Nope. They should have made a link going here.
Blkcasper
Blkcasper's Gravatar
02/29/20 5:06 PM
Yeah, the other forum was closed down. Lee only has a face book page now.
Luvin My ZX14R'S.
03/02/20 4:57 PM
Hey "O" How are ya doing??
BIGO70
BIGO70's Gravatar
03/02/20 11:55 PM
You mean me???
Curtis
04/17/20 9:24 PM
Hey , Could Someone help me with an issue I'm having. I have a 2012 ZX14r and as I am riding it and I give it gas , it ask like it doesn't want to take it. I have change the plugs , Fuel filter and pump , I also change the oil. I put everything back together and it fixed the problem. when I took the filter off it was trash in it ( grey Matter ) it look like the top of the gas cap. So I started my investigation and took the gas cap off and it was nasty inside so I replaced it so I'm thinking problem solved. The bike was running fine for a couple of days now its doing it again.
Please I want to ride and I need some help.
04/18/20 7:26 AM
Tank has rust? Sounds like a clogged fuel pump. Pour the gas in a clean container. How much shit came out of it? Remove the fuel pump. Literally submerge it in the container of gas, slosh it out around so the L tube that feeds the injectors, to kind of backwash, or dislodge the rust particles. If the rust looks like the surface of mars, you found it.
Another test before emptying the tank is to turn the key on, have a beaker by the L outlet tube going up to the throttle bodies, see how strong it pisses? To start it, it won't dribble out, but maybe it won't be as strong a flow. It only cycles at so many seconds before the ECU turns it off. You might need to cycle the key to see another sample flow.
Like I said, about 42-44 psi is the output pressure behind the injectors. 33 psi say is that it starts, but fuel demand drops off and so does the nose of the bike. The slosh of rust is going to be that black plastic filter. That guy cannot be replaced. The rust is so fine it's like powder. If rust is laying on the top side of the fuel pump plate when you remove it, Bingo!
Edit: I see you changed the pump, but was it new or used?
* Last updated by: Hub on 4/18/2020 @ 7:29 AM *
jstewart
09/04/20 9:57 AM
Cost and maintaining the website according to Lee.
09/04/20 8:32 PM
A few people paid that site a few bucks to support, when that ran low because the Ahole who ran it started to trash the opinions of the people on it the Ahole bailed
09/04/20 8:32 PM
09/04/20 10:22 PM
Ouch...
09/04/20 10:40 PM
Let me get this right, Lee took my signature literally?
Wha happin? You mean something like, 'you'll never get a good ET with that kind of tire pressure, that's the pressure you use for your penile machine, you little jerkoff'.
* Last updated by: Hub on 9/4/2020 @ 10:41 PM *
